Results 1 to 7 of 7
    Default Crimson cat, t-tops conversion
    Looking at a crimson cat locally, its in excellent shape. My question is it has t tops that were added later what does this do to value? They dont leak and are reportedly from a 83-84 mustang so period correct. Prefer cars lime this to be all original. Trying tondecide if its wortg it or if i should put the money into my 82 rs restoration instead.
    Aug 2003
    Villa Park, IL
    Who did the t -tops? Cars and Concepts or someone else?
    Quote Originally Posted by MIKE'SVO86 View Post
    Not sure. Looks factory though. Just not on the build sheet. Guy says the previous / original owner had the dealership do it, who they had do it i have no idea
    You know where the code would be on the build sheet, and what that code is?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Double post
    is it just TR on the buck tag?
    Quote Originally Posted by nimoryan View Post
    For 83, yes. That code would be about in the middle of the second line. In earlier model years (1979-81), Fox Capris and Mustangs were produced at two assembly plants, and their buck tags were completely different. The San Jose plant spelled "TROOF" on their buck tags, and put that code on the last line.
    Before you mentioned the build sheet (assembly line broadcast sheet) though?
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
