Results 1 to 4 of 4
    Default '83 GLX conv - 4 speed - 5.0 Hazard not working
    Hazard "blinkers" not working. Turn Signals OK. Got 12 volts on both sides of the fuse
    Is there a separate flasher for the Hazard lights? If is, where is it located?
    Thanks for your help!
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    I do believe that the hazards have their own flasher. IIRC it's behind the passenger side of the dash above the glovebox. In the image below it's the second from the left as viewed. I'm not sure what year this is from or if all years are the same. Hopefully this helps.
    Name:  electronics behind pass dash.JPG
    '85 GT
    Found it right where it is pictured. Flasher was bad - replaced it, and now we are flashin' !!
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Outstanding! Glad the info helped!
    '85 GT
