    FEP Member svo84's Avatar
    Oct 2006
    York, Pennsylvania
    Default 1981 Fairmont wagon decode please
    Might be picking this up. 81 Fairmont Wagon.
    Vin: 2FABP23D5BX146581
    That pic is too small
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    True story
    Name:  146581 - 2FABP23D5BX146581 - 1981 wagon.jpg
    VIN
    2FA = Ford vehicle manufactured in Canada by Ford Motor Company
    B = active belts, no airbags
    P = passenger car
    23 = Fairmont 4-door station wagon
    D = 4.2L V8 engine
    5 = VIN check digit
    B = 1981 model year
    X = St. Thomas Assembly
    146581 = 46,581st 1981 Ford scheduled for production at St. Thomas Assembly
    Door Tag
    Date - 12/80 = December 1980 scheduled build
    GVWR - 4487 LB/2035 KG = gross vehicle weight rating
    Front GAWR - 2243LB/1017 KG = front gross axle weight rating
    Rear GAWR - 2275 LB/1031 KG = rear gross axle weight rating
    F0167 = 167 lbs front accessory reserve load
    R0173 = 173 lbs rear accessory reserve load
    Exterior Paint Colors - ??
    DSO - ??
    Body - 74B = Fairmont 4-door station wagon
    Int Trim - GT = vinyl bench seating (G), Caramel interior trim color (T)
    A/C - A = factory manual air conditioner
    R - 2 = AM radio
    S - [blank] = no flip-up open air roof
    Ax - G = 2.26:1 axle ratio, open/non-locking differential
    Tr W = Ford C4 automatic transmission
    55 = front coil springs
    FF = rear coil springs
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    VIN Decoder
    Oct 2006
    York, Pennsylvania
    Thank you. Soon as I get it I will send a better picture. Buck tag is on top of the rad support also.
