Results 1 to 6 of 6
    Default 83 Fuel Pickup/sending unit upgrade
    Changing my '83 over to 3/8 fuel line but wish to retain the original style sending unit for my gauge. Does anyone make a stock type sending unit/pickup that is upgraded to a 3/8 pickup tube rather than the 5/16"? Or another solution? InLine Tube sells the complete 3/8 fuel line for these cars so I feel like others have run into same issue. Seems like several manufactures make something similar for the 87 up cars, but not for the carburated cars.
    FEP Power Member qikgts's Avatar
    Jan 2010
    Rockledge, FL
    UPR sells one. -10AN feed fitting and -6AN return. Screw on barb fittings shouldn't be real expensive to make them the size you need.
    https://www.uprproducts.com/79-99-fo...l-pickup-tube/
    '85 GT
    That is just a fuel pickup, no sending unit for the fuel gauge.
    Jan 2010
    Rockledge, FL
    If you don't have an EFI style tank, I think you're going to have to modify what you have now to get a larger size line.
    With an EFI style tank you could use the pickup I posted with the separate EFI style sender.
    '85 GT
    FEP Power Member grtskydog's Avatar
    Sep 2003
    Carolina Beach, NC
    How good are you at brazing?
    Ed
    "The Dude abides."
    Quote Originally Posted by grtskydog View Post
    Unfortunately, have not done that before.
