Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 101 to 125 of 294
  1. #101
    FEP Power Member 86-TC/SVO's Avatar
    Aug 2010
    Connellsville, Pa
    Default 130amp upgrade
    I finally got to do an alternator upgrade to my 87 TC. Not that I wanted to (trying to keep original as possible).
    Knowing how the older ones had issues. I bought the 130amp alternator and power wire from American Muscle last year before Ford Carlisle but, didn't really have the time to do until this year. I knew I had to modify my power steering pump bracket to accommodate the size of the new alternator. Used a die grinder to massage enough material out of the way (sorry no pics before and after of that). This link has some pics of the bracket. https://turbotbird.com/thread-3g-alternator-install. Moved wires around for the wire that plugs in for the car (pulling 2 wires out of factory plug and switching their places) insted cutting and splicing. I didn't do enough research on everything, because the power wire I bought was too long, so I ordered the shorter one and got it installed the other week. Just now getting to post about it. Here is the link to AM for some of my finished pics. https://www.americanmuscle.com/profi...eimage=1719373
    86' SVO 1C # 17 of 3379 86's #6475 of 9837
    86' SVO 1C #497 of 3379 86's #6955 of 9837
    84' GT Turbo #4 of 3241 GT Turbo HB's #560 of 3935
    87' Thunderbird TC 1 of 10
    http://www.foureyedpride.com/content...e-of-the-Month
  2. #102
    Jan 2003
    Muskegon (Power Tour stop!)MI
    Nice! Is this a doable swap on the 83-86 TC cars?
    '86 GT - weekend driver
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
  3. #103
    Aug 2010
    Connellsville, Pa
    Yes, it is.
    Here is another link that will help for older models. http://www.rothfam.com/svo/3g/
  4. #104
    Been tuning my car, but been raining for 2 days so waiting for rain to stop
  5. #105
    Did some paving on the Cobra. Forgot how much I hate bondo.
  6. #106
    Quote Originally Posted by ITdude87 View Post
    Yesterday -
    Finally got the tint re-installed with the correct (ceramic) film. 15% on the hatch, 20% on the sides.
    Looking good!
  7. #107
    Thanks! I went back and forth with the percentages trying to match the decals/trim as best I could. I think it turned out wonderful in person and was worth the wait.
    Not much left to do at this point in my opinion, other than enjoy it (famous last words). It was a pretty productive "off season" getting all the little kinks and touches ironed out, and the car is finally at the point where I wanted it to be outside of maybe some more spit shining.
    I do need to get it in to have the AC charged up fresh, and maybe the rear end and transmission fluid flushed out for good measure...but other than that...I'm ready for the nice weather cruises and a few shows.
    1986 Mustang GT - 2A, 5 Sp
    2018 Subaru WRX (Daily)
  8. #108
    FEP Member Hans's Avatar
    Jun 2008
    the Netherlands
    That's a beautiful car .
    Verstuurd vanaf mijn CPH2219 met Tapatalk
  9. #109
    Bumping this one since folks keep posting in the "2020" thread by mistake.
  10. #110
    Default its not 2020?
    Moved the post. Thanx guys. A senior member moment.
    Nice day 80's no wind. Mostly overcast no sun beating down.
    Engine stuttered a bit the other day. Decided to have a peek inside the carb bowl.
    Upgrade carb install is going on 4 years of driving bliss.
    Original plan was to change power valve from 8.5 to 6.5. An experiment to see what..
    Carb stayed on engine. Is a Holley 2300 series 350 cfm 2v.
    First removed sight plug to check fuel level in bowl. Level ok.
    Removing the 4 bowl screws: Three barely clear the strut tower bar and top of alternator.
    Had shop rags stuffed under front of carb.
    Drained bowl by removing lower bowl screws. Needed long 1/4" extension with 5/16 socket.
    Once the metering block was out, decided to also change secondary jet from 55 to 56.
    Left primary at 55. Jetting was a guess converting over from stock Holley 5200 carb.
    Noticed had bowl vent baffle installed upside down and in front of gasket. Corrected that.
    Reassembled carb.
    Engine started ran real rough gas poured out under metering block.
    Took it apart and reinstalled the 8.5 pv. Was the 6.5 ng? Dunno. Looked ok.
    Reassembled 2nd time Same deal. Gas on everything under front of carb and on ground.
    Why did i not leave things alone?. Carb was fine before fiddling with it.
    It is not the FEP way.
    Disassembled again 3rd time.
    One lower bowl screw gasket flew off somewhere and walmart has no extras.
    Looked and looked at nooks and crannys in area below carb,
    Found it under car on driveway location under rear of k member. Luck luck luck. Took a coffee break.
    A round black nylon gasket in an oil and gas stained area of driveway. Bright flashlight was gold.
    Reassembled and made sure bowl and metering block and bowl were square and seated.
    All screws now threaded almost all the way by hand like they should have prior.
    No more leak and car drove fine. Seems to have a bit more umph from 1/2 throttle.
    Will get a new 6.5 pv, extra screws, screw gaskets, maybe jets and try again.
    Carb otherwise was clean inside.
    Ain't those reusable Holley blue gaskets purdy? Gotta be worth 5 more hp.
  11. #111
    Installed a 2.5lb. Halon extinguisher in my 86, got the bracket from NPD and then the fun started. They claim there are two holes to mount the bracket in the car .but didn't give any further instructions. Well one of the "holes" is between the seat and the sill panel and as I found out later is measures approximately 3"X3 1/2" in diameter. I had to fab a plate to fit under it between the the bottom floor pan and the seat pan then line up the bracket with the retaining bolt. Plus drill a hole for the other bolt on the bracket which came out on the other inside of the frame rail, all the while laying on my back. Rather than blather on about this if anyone needs advice on this in the furture please feel free to contact me and I'll be happy to help you out. Daryl 608-751-9653, if no answer leave a voicemail. The phone rings about 13 times before the leave a message comes on.
  12. #112
    Noticed a hairline crack middle of w/s above r/v mirror down almost to the bottom. Chassis flex i guess.
    Is a Carlite W900 tinted. Replaced in back in the 80's.
    Checked NPD site Whoohoo In stock. Coupe and Hatch.
    Darn was right near the Mich NPD store this afternoon but was almost 5pm.
    Oh well. Will be there very soon. Hope the box fits in the car.
    Have to dig out a tab mount bracket style mirror. Current set screw style mirror mount won't work.
    Says replacement style exact blackout is different. Shucks car has a lot of multiple year parts anyway.
    Glad to see it go. Was going to do it anyway. Will look great again at a show.
    Glass looked sandblasted from day one. Glare too. New ones look invisible.
    Should have taken it back to the glass place right away but had a heavy work schedule and let it go.
  13. #113
    Finally got her down off the jackstands with new shoes.
    [ATTACH]138182[/ATTACH
    Engine fired after 4th turn of the key. All good so far.
    W
  14. #114
    Capris are so mean. I don’t recall seeing too many in white William, love it!
  15. #115
    Default drive to bbq
    Hot today already 80-90 clear sky and calm. Perfect.
    Driving the Cobra across town to the usual summer afternoon holiday bbq at S's house. Shaded patio no 'skeeters yet.
    Grew up with her and her brother lived a block away. Long time close friends. Many good times continue.
    Kingsford Charcoal chimney starter tool. Grill two t-bones one for today one for later..
    Load up cooler and 19" LCD tv for watching postponed NASCAR Coke 600 ota outside on the picnic table.
    One year started to rain hard new gutter leaked put out the fire soaked the food.
  16. #116
    FEP Member 0F0 CBR's Avatar
    Feb 2019
    Ontario, Canada
    Decided to give up on the old Holley boat carburetor I have been using for 35 years and installed a new Edelbrock AVS2 500 CFM on my Mustang.
    Set the idle, changed the plugs and went for a rip. Works great, nice and smooth with no hesitation. Also it got rid of the sulfer smell from the catts I had when pushing it.
    Should done this years ago.
  17. #117
    Thanks IT, She gets some attention on the road. Time to hit some shows and enjoy the weather and people. Looking forward to Ford Nationals in a couple of days and the new Motor City Foxfest in July.
    W
  18. #118
    Jun 2013
    San Diego, Ca.
    My 83 RS Capri getting some TLC. Front end fixed, sealer and 4 coats black lacquer and 4 coats clear. Anticipate paint in the near future. Sonic Blue Pearl over black primer. SN95 front and rear calipers have been powder coated (near body color) and rebuilt.
    conmech - aka Marshall
  19. #119
    Quote Originally Posted by WilliamCapri View Post
    Looking forward to Motor City Foxfest in July.
    I’m really looking forward to going to that show as well. I ordered a hat earlier today.
  20. #120
    Stopped by my first show ever on Saturday.
    There were only about 3 79-86 cars that I saw, one of them being all clapped out and modified for racing. Here's the other two. Doesn't get any better than these two examples - but I am clearly biased.
    ZEN50’s Capri
    My 86’ GT
  21. #121
    FEP Senior Member fascat's Avatar
    Greensburg, PA
    Thanks for posting the pictures ITdude87. Your car looks great. ZEN50's Capri is one of my favorites. Been a fan of the Capris since the late 80's when I had my first '86.
  22. #122
    The Capri is absolutely stunning in person, I agree.
    Appreciate the compliment!
  23. #123
    Jan 2003
    Great pics Tim, thanks for taking them. Your car looks great!
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
  24. #124
    I was wanting to go, and bring up the LTS, but July is looking to be an overly busy and expensive month for us this year. Maybe next time around.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
  25. #125
    Default Cruise time in Metro Detroit Eastpoint/Gratiot Ave.
    Drove across town to first major 2023 city sponsored annual cruise Saturday. Special one to me.
    Section of the old stomping grounds. The Cobra was delivered new to Ford dealer there in '78.
    Brought coolers and good old vintage vinyl strap patio chair.
    Cruise/car show size is two miles long north and sb. 50's-90 classics as it should be. Lots of fox.
    Prefect weather 85 and clear with breeze. Hundreds of cars cruising and parked. Traffic moved well.
    Stayed 12p-8p. Met up with family and friends.
    Heading SB, by luck caught them waving frantically to me from a car lot across the road on the NB side.
    Was generously invited to use the building restroom. Clean flush toilets are a big plus at any all day car event.
    Being gap guided into parking space in front of the 66 Mustang, discovered DS backup light was not working.
    Couple pics posted in events/regional/midwest thread.
    Seen a pickup truck blow a coolant hose big time after a short burnout at a light. He kept going.
    From the looks of what the street looked like, surely not far. Plenty of flatbed tow trucks were around.
    Darn missed doing a short video of that.
