Results 1 to 6 of 6
Thread: O2 Location?
    FEP User Fast_4_Eye's Avatar
    Oct 2021
    Cobourg, Ontario, Canada
    Default O2 Location?
    Alright guys, so I managed to get my hands on some headers off Facebook Marketplace. They don't have a brand to them but are ceramic coated and very clean. Guy wanted $200 CAD so I had to scoop them up.
    Anyways, my main question here is that the O2 sensor bung is in the primary on both of the headers, however, there is no hole for whatever reason so the bung goes into the side of the header. Should I drill it out? or should I take it to an exhaust shop and: A) have them clear out the area in the bung so I can use my 02s or should I B) have them weld a new bung in the collector instead of primary.
    Also not sure if anyone can help with brand but the guy said that they just came off a project '85 he had sold for scrap so I'm not even sure if these are any good but I like the idea of long tubes.
    Here are the pictures, mind you not the greatest: https://imgur.com/a/5PfEmiB
    So interesting. The bung is up in a single cylinder? If so, yeah, cork it and get her down lower. Mine are down in the h pipe but I have shorties. I would definitely put yours in the collector.
    I use the plural since I have one in the driver's side for the CFI and another in the passenger side for the afr gauge when I want it
    Oct 2021
    Decided I will keep in in the primary as apparently it helps keep the O2 warm so I'll stick with that and hope for best.
    Any recommendations for things I need to do after installing long tubes?
    The only concern about the primary is cylinder to cylinder variation can be quite high. If tuning becomes a problem you might want to move it later.
    Oct 2021
    My thought exactly, but as of right now I'm going to be stock, maybe heads and a cam. Once I start seriously building the car I'll probably look into the high end ones but for the time being I think these should do alright, now I have to look at heat wraps and a mini starter.
