Results 1 to 4 of 4
    Default Aftermarket pulley system
    Looking for suggestions for aftermarket pulley system. Alt, p/s & waterpump.
    any help is appreciated
    If you are just looking for the 3 main pulley replacements, there is March, ASP, BBK, SVE, and probably a few others. Most are underdrive style that in my experience are not the best for the average cruiser, daily driver, etc. If you are trying to get that last bit of power, then might be worth it.
    March and others offer full accessory mounting kits, brackets, etc. if you are going with a non OEM setup or just want to dress it up or change it up. Good Luck!
    Looking for a complete system with brackets, pulleys, etc. New motor coming soon would like something that looks better then stock setup
    FEP Power Member qikgts's Avatar
    Jan 2010
    Rockledge, FL
    If you have the money, I'd look at the Front Runner system from Vintage Air. Pretty killer set up and it does away with the timing cover, and March has one that does too.
    https://www.vintageair.com/custom/pr....php?pn=174100
    https://marchperformance.com/ford/fo...g-30410-c.html
    '85 GT
