Results 1 to 4 of 4
Thread: Moates closing
    Feb 2009
    Jackson, NJ 08527
    Very sad to see that. I have a lot of equipment from Craig. Hopefully someone steps in to take over. He supported not just Ford products.
    steve
    Feb 2012
    Mississauga Ontario, Canada
    It is very sad, I have the moates qh set up on my 85. It works great.
    qikgts's Avatar
    That sucks. They made really great products that were well thought out and provided affordable, practical solutions to keep using factory electronics.
