    FEP Senior Member 9DBlackMagic's Avatar
    Sep 2006
    Antioch, California
    Default Driveshaft Question
    Hello everyone I have a 1982 Capri V8 with a s-rod transmission I have a five-speed that I want to do a swap with can my s-rod drive shaft will work with the five-speed
    ~LES~
    157 HP @ 4200 RPM
    240 ft/lb @ 2400 RPM
    Capri:
    Mar 2003
    Lowell, Oregon
    When I put the t5 in my '83 hatch I seem to remember I used the driveshaft again. I think.
    Sep 2006
    Antioch, California
    Thanks for the help sir
    ~LES~
    157 HP @ 4200 RPM
    Capri:
    Jul 2010
    Houston (Clear Lake), Texas
    It's been a really long time...around 86...since I swapped the Srod 4 speed in my then 82 GT to a T5, but I don't recall having to use another driveshaft for the T5...
    HAD
    HAVE
    Have a 1992 1352-209 2.3 T5 in my 79 2.3T.
    Car came with a RAD trans (4 speed, 4th 1:1 no o/d) from factory.
    Changed to a '91 5 speed Mustang drive shaft from salvage yard in 2002.
    Wire wheeled and repainted it before install. U-joints were fine.
    The oe ds was a bit too long to me. Front yoke was deeper into the trans.
    The replacement matched the same yoke depth as the RAD combo.
    2.3 5 speed ds is 41.5" long, 7.5 rear. V8 is prob the same one.
