Hi,
With all the upgrades to make the car more usable, the stud on the starter relay is starting to look like a star burst, and I'm not sure I can get anything more on it, but need to run a wire for the fuel pump.
What I currently have: the stock wires, one for the fan relay, one for the headlight relay, one into the cabin for all the gauges there, one for the stereo. Soon one for the fuel pump.
The negative ground is almost as bad, but that is already a long bolt so I _could_ replace it.
If I wanted to take this all apart and do it 'right' what do I need? A single insulated stud? Some kind of junction block? Any pictures of where others have mounted their solution?
Thanks,
Chris
