Results 1 to 2 of 2
    Default Oil drain plug sizes
    I was reading other forums trying to find the correct size oil drain plugs and I ended up more confused.
    someone said some Fox bodies were standard and some metric. If that’s the case, does anyone know which years were what?
    my car is an 82.
    Also, I noticed the front plug was much shorter. Is that necessary? I’m guessing the parts store will just have one length, but wanted to make sure there’s not a clearance issue that necessitates the shorter plug up front.
    Mar 2003
    Lowell, Oregon
    No clearance issue. The only thing swinging around down there is the crank weights and rod ends. IIRC mine on my '83 were 7/8?
    If you want new plugs take one that you know fits (like when you drain your oil to change it) and go to the parts store with it to compare. Don't worry about that slight length difference. Sometimes a slightly longer one simply had a magnetic end to catch metal.
    The pans all interchange, but it is possible the thread of the drain plug changed.
    But if you get ones longer than what you have and want to check, install them then turn the motor a few revolutions by hand.
