Results 1 to 2 of 2
Thread: Crankase vent
    Jan 2003
    Muskegon (Power Tour stop!)MI
    Default Crankase vent
    What are you turbo guys using for a crankcase vent at the valve cover? Trying to find a replacement for my 86 Turbo coupe and can't find a stock one. Might go with an SVO one and drill out the valve cover hole to the larger size?
    https://i.ebayimg.com/images/g/qyMAA...Ct/s-l1600.jpg
    '86 GT - weekend driver
    '86 Capri 5.0
    '86 Turbo Coupe
    '17 Mustang GT
    '23 BRONCO
    A lot of engines have a rubber hose connected from the v/c to the air cleaner or air box.
    At the a/c end is a small filter pad. Or the main air filter does the job.
    Old style engines or racing motors have push in breather(s) with filter media inside.
