Results 1 to 3 of 3
    Default Brake Booster Question
    Hello All,
    Working on an 85 GT here. How does one go about checking out the brake booster to make sure it's in good shape? As an FYI, the car was taken off the road in the early 90s and not driven regularly since. Everything worked fine at the time it was parked but of course it's been sitting for almost 30 years.
    Thanks in advance!
    BG
    Pull the vacuum hose off, plug it and test the brakes. Put the hose back on the test the brakes again. Make sure it is getting vacuum from the engine.
    Jan 2004
    Olathe, Kansas
    brake pedal will be very hard, like manual brakes if its not working.
    Now stang-less.
    88 Cougar 5.0
