I took the followers, lifters and camshaft out last night and found the #1 and #3 exhaust valve stem seals were messed up.
Little hard to see #1 was ripped from its base
And #3 looks like it was crushed and broken.
I tried to get the valves out but i guess i need a different spring compressor because it wasnt happening with the universal ohv one i had.
On the plus side this weekend ill head on back and get started cleaning the block and checking/chasing the bolt holes, two of the bolts had a lot of material on them when i pulled them out so i worry about them. Hopefully i wont have to put in a helicoil in them.
