Results 1 to 3 of 3
    Jan 2007
    Quartz Hill, California
    Default RS Capri Brake problems after 87+ update
    14 years ago, when I first got my 84 RS Capri back on the road, I upgrade the rear end from a 7.5 four Lug drum to an 87 five lug 8.8 setup with the factory Mustang drums that were on the rear end I pulled from the parts yard. At the time I still had the factory front brakes on my car and the brakes seemed to work pretty well. When I did the UPR K-member swap a year or so ago the brakes were still working fine before I upgraded the front spindles, rotors, calipers and new brake lines to new 87+ parts. I only drove the car several times after the upgrade and never really stomped on the brakes to test them out until the last time I drove it before the fuel pump went out. Something is definitely going on with the brakes! The front drivers side brake locked up and the passenger side felt like it barely had any brakes at all, and I don't even think the back brakes are working! Scared the crap out of me! The brakes are all bled properly so I don't think that is the problem.
    Anyway, I am not a brakes guy, I understand the basic concept but definitely don't know the ins and outs of the system. Where should I start to even trouble shoot what the problem is? My normal auto repair guy won't touch it with a 10-foot pole because of all the changes I made to the stock system and says it would be a liability nightmare for him LOL, so I am turning to my fellow FEP mechanics for help.
    Thanks in advance for any help or pointers you guys can give,
    Robert
    Pic of the RS with the newly acquired Trans AM
    My RS in Action
    Feb 2009
    Jackson, NJ 08527
    New brake hoses I assume? May be a caliper sticking on the one side not working.
    Jack up back of car, put jack stands under it. Put car in gear and hit brakes. See if rears stop.
    If rears are getting pressured fluid during bleeding, they have to be doing something.
    Jul 2004
    Montebello, CA
    you have to use a larger master cylinder if you went to a larger caliper also remove the proportion valve spool and make sure it moves as they will jamb up
    Past 4 eyes-
    U.S. NAVY 1980-2009
