Results 1 to 5 of 5
    Question Small Hole in Floor Pan
    Hello All,
    I found a small spot on my driver side floor plan where it's basically rusted through. You can't see through it because of the rubber coating on the inside of the pan, but I could punch right through it with a screwdriver.
    Pix attached. The circle on the floor in the interior picture shows the location - what's a simple but effective way to fix this?
    On my car, i just cut out the rotted areas and welded in new pieces.
    Cut and weld.
    83 TC "Clone"
    85 Marquis LTS
    Mar 2008
    darien il
    if you do not have the tools space to cut and weld. i have delayed the problem by putting a fiberglass patch on it. since the car was my daily driver i needed it to go to work the next day. scoffed up the areas with a wire wheel, put on the fiberglass per the instructions. 10 years later still there. i did put/spray the bottom with a rust additive and later paint to cover it..
    Quote Originally Posted by bob85gt View Post
    That is not a bad option if you cannot weld. We did the same thing when we found some rust in the floor of our '67 Biscayne. Back then you couldn't just order up new floor pan parts and we didn't have a welder anyway. It's been nearly 30 years and they are still there. Make sure you get all of the rust out and treat it as mentioned so it doesn't continue to rust.
    '97 Thunderbird
