Results 1 to 4 of 4
    FEP Power Member David Claflin's Avatar
    Oct 2008
    Redneck Riviera, Fort Walton Beach Florida
    Default Resistor on the back of the gage cluster, 1985 LTD
    Battery light is on, the lt/green red wire that goes to the alternator through the light/resistor only has 3 1/2 volts going to it. I'm getting 12V on the red/lt.green from the switch to the light/resistor. The resistor shows being open, anyone know what value that is supposed to have so I can replace it as I think that is the culprit.
    1985 LTD LX, Mach1 brakes, 17" Mopar police car wheels. 302, T5, 4.10s
    1986 FHP coupe, stock shortblock, TW heads, Holley SMII intake, 4.88, T5Z
    1990 Red LX, ported AFR heads, TFS-R box upper, weenie cam, 1 3/4 long accufabs, 3" exhaust, T5, 4.56
    Oct 2008
    Disregard, realized i checked it wrong. Dang, thought I was onto something.
    Is it that funky voltage regulator thingy that turns it to 6v for the dash?
    Oct 2008
    No, just the resistor that still lets power go to exciter wire on the alternator if the bulb burns out.
    I'm only getting 3.5volts to that green/red wire...., but I did find that resistor is 500 ohm.
    http://www.veryuseful.com/mustang/te...nks-ign-ac.gif
