Results 1 to 6 of 6
    Default A little walk around with my 1984.5 gt350
    Posted this on YouTube today. Figured some of the folks around here might be interested too.
    https://youtu.be/ZwhdTBjazjc
    Nice...
    Nov 2004
    Chas. SC
    Nice, It almost looks like mine except mine doesn't have that black folding thing..
    My original paint isn't quite that good either.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Jan 2004
    Olathe, Kansas
    Very nicely modded and upgraded car. With the intake and exhaust and gt40 heads, how did you keep it from leaning out? That is a lot more airflow than stock cfi.
    Now stang-less.
    88 Cougar 5.0
    It was interesting, I was very worried about that so I brought it to the dyno after each change and installed that AFR gauge. We only ended up adding maybe a lb or two on the fuel pressure regulator. The system was able to compensate quite a bit on its own. That said, it definitely uses more and is capable of using far more fuel than it could stock.
    qikgts's Avatar
    Jan 2010
    Rockledge, FL
    Good vid! Thanks for sharing!
    '85 GT
