Results 1 to 10 of 10
Thread: holley sniper
    Post holley sniper
    Thinking of switching to a Holley sniper system on my 86 gt. I currently have an A9L MAF converted tuning with a Moates quarter horse, and having one hell of a time getting it to idle. Actually, it's Almost impossible to get to idle. It's a simple combo. 306 heads cam intake combo, been done probably a million in one time. Who has installed on and what "extras" are going to be needed aside from a carb intake? Also how do you like them for those of you that have installed them?
    I was going to ask why go through that much trouble and cost when Holley makes the Terminator X kit for the 87-93 Foxbody. https://www.holley.com/products/disc...parts/550-937F but apparently they have discontinued that product now. They do offer the universal kit https://www.holley.com/products/fuel.../parts/550-937 that most likely you could make work and not have to swap out your intake and all the other related parts. That is unless you just want to swap the intake out and make all the other changes. Good Luck!
    Feb 2012
    Mississauga Ontario, Canada
    I have the moates qh on a A9L on my 85 gt. I got my car to idle and start up great. If you look up the forum on eec tuning or efi dyno tuning. Their is a guy on their that tells how to get the idle just right. The moates qh is great but it has a vey steep learning curve.
    New User
    Oct 2015
    Texas Hill Country
    Ive installed a few Snipers on customers cars with good feedback results. I put one on my personal fox body Tbird with a 351w. Im very pleased. I even used a stock fox body fuel pump. Easy peasy install.
    Stinger Performance PimpXS. Plug and play, great support and endless tuning options.
    Megasquirt is easy to learn, tune, etc. I was going to do a MAF swap last year, decided to keep it SD and swap ECU's instead. Amazing setup, wish I would have swapped years ago.
    Jeremiah
    1986 Mustang GT 5spd, 3.27's
    Quote Originally Posted by Two86fiveoh's View Post
    What system are you using? The stinger PimpXS?
    Yessir. Swapped over late summer/early fall of 21'. Phenomenal setup. This is the ECU I'm running:
    https://www.stinger-performance.com/...ine-management
    Jeremiah
    FWIW--I also run shadow dash through a 7" Android touch screen mounted in the factory single din hole. No cutting required and costs less than $100
    Jeremiah
    The link, stereo quality sucks. All else is spot on.
    https://www.aliexpress.com/i/3256801...apt=4itemAdapt
    Jeremiah
    Jan 2004
    Olathe, Kansas
    Wonder why the quit the mustang specific kit? Emissions fears, probably. That sucks
    Now stang-less.
    88 Cougar 5.0
