Results 1 to 6 of 6
Thread: Roll cage
    Aug 2011
    Clarksville, AR
    Default Roll cage
    84 Ltd lx 347 t5
    What are my options on roll bars. I have looked at maximum motor sports. I don’t want anything extensive, just a 4 bar setup. I don’t want a bar right behind or above my head. Not concerned with backseat room.
    There's a guy on a Facebook group that I'm in has a roll bar set up in his LTD. His name is Charlie D Benton, I'd post pictures but for some reason every time I try I get a message that it failed.
    The group is https://www.facebook.com/groups/fordltdlx/
    Feb 2009
    Jackson, NJ 08527
    Quote Originally Posted by Asphalt View Post
    Sick pic on their main page
    Aug 2011
    Clarksville, AR
    Thank you, I will look it up.
    Feb 2009
    St Augustine FL
    bgriff,
    Here are the parts I used. They were made for a Fox Mustang but ended up fitting the 1981 Mercury Zephyr wagon surprisingly well. The major mod was to use a hydraulic bender at our local muffler shop to get the rear angled supports pointed downward toward the ground in the area just behind the rear seat. The seat and luggage area are usable and the whole thing is SCCA approved. I especially like the removable door bars (removed in the attached photo) and the belts attached to the horizontal bar just behind the top of the front bench seat.
    Competition Engineering C3000 8 Point Roll Cage Strut Kit
    Competition Engineering C3020 Roll Bar Bolt In Conversion Kit
    Competition Engineering C3039 Main Rollbar Hoop
    Competition Engineering C3185 Rear Formed Roll Bar Strut
    Name:  Zephyr front pass seat web.jpeg
    Name:  Zephyr rear floor carpet 1 web.jpeg
    DISCLAIMER: This was done 10 years ago, so numbers and pieces may have changed!
    Hope this helps,
    Tom
    Aug 2011
    Clarksville, AR
    Tom,
    Nice set up, thanks for the info.
