Results 1 to 15 of 15
    FEP Power Member 86darkside's Avatar
    Jan 2009
    new jersey
    Default Window wont go up or down.
    I changed the the motor thinking it was no good tested both motors and they turn i also bought a new switch and nothing ,i used a tester and the switch is getting power ..can it be the window regulator?
    Nov 2004
    Chas. SC
    take the door panel off and see what's happening when you hit the switch. I would be willing to bet the alignment bushings are bad. The regulator is all steel with plastic guides that age out.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Jan 2009
    new jersey
    I took it off ..flip the switch many times up and down nothing is happening. Was working right.
    Nov 2004
    Chas. SC
    can you lift the window by hand with the motor removed? Is it setting square in the tracks? top should be level as the window is raised.
    Albert Einstein
    Almost "Stock"
    Jan 2009
    new jersey
    Yes and yes
    Nov 2004
    Chas. SC
    only thing I can figure is that when you put the motor in it is jamming the mechanism. The motor should run and stop all by itself when it gets to the stop.
    I had an issue with mine that the window "stuck" down. I pulled the motor and it ran fine. Put the motor back in and it worked again????? I ended up replacing the motor channel guides and weatherstripping anyways and it works like new. Not sure what the problem was but it sounds almost identical to yours.
    I would hook the motor up test it and if it works again put it back in. I know this is a more painful the bigger your hands are but... Otherwise i'm clueless. Sorry
    Albert Einstein
    Almost "Stock"
    Does the motor even try to drive the window up and down?
    Sep 2010
    Lexington, MA
    Is it possible the window bracketry is binding? Had a similar(manual) window problem on my '65.
    Jan 2009
    new jersey
    Nope nothing i took motor out test it and it turns but when i put itback nothing .
    Nov 2004
    Chas. SC
    Only thing that makes sense after reading and rereading.. The motor has something built in that stops it when the window is at a hard stop. The force required to move the window must be greater then the internal stop load can overcome. I would get another new motor and see what happens. LMR sells them for a decent price.
    Albert Einstein
    Almost "Stock"
    Jan 2009
    new jersey
    Found the culprit…a new bad window switch.
    Thank to all who provided answers.
    Nov 2004
    Chas. SC
    Thanks, Good to know!
    Albert Einstein
    Almost "Stock"
    Becoming a more and more common problem. Never assume that a part is good because it is new.
    Barboursville, WV
    Quote Originally Posted by PrecisionTrans View Post
    I learned the hard way, many years ago, not to presume a part is good just because it's new. That is even more true these last couple years!
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    BANZAI.. Lost the battle but winning the war......
