Oops, that was a little unclear. I meant the tailpipes had the hangers welded on.
One issue I've run into too is depending on how you have the tailpipes adjusted forward/back or rotationally, the right side one will touch the gas tank. But if you try and get everything straight and the mufflers where they're supposed to be, there is a gap. Mine still have to be tweaked to get them far enough away from the frame rail over the rear axle. It's a process, haha.
