Results 1 to 7 of 7
Thread: TR3650 swap?
    Barboursville, WV
    Default TR3650 swap?
    I just got my hands on a bellhousing adapter that is supposed to allow bolting a tr3650 or t45 to a Windsor motor. I may or may not end up doing the swap, but it sounds interesting. I'm just curious if any of you have done it. I think the biggest hurdle is getting a working speedo. You can buy a gps device that converts the signal to cable, but they're a little spendy. I'd have to figure out the starter and clutch fork setup too, but those might be simple.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Grand Rapids, MI
    Is it a 4.6 to SBF adapter plate or some kind of custom full bellhousing? I'm certainly no expert on the 3650, but I thought the bellhousing on those was a little more integral with the trans. I know Hanlon makes an adapter plate to allow for bolting a 3650 to a T5 bellhousing. Do you have any more details on what it is?
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '91 Crown Vic P72 351W
    '97 Thunderbird
    '85 Ford LTD Squire
    Barboursville, WV
    It is an adapter plate that allows the 3650 bell to bolt to the windsor block.
    https://youtu.be/4jKkmEFEDdg
    Barboursville, WV
    Grand Rapids, MI
    Ah interesting. I suppose it could be pretty cost efficient if you could find a good used trans for cheap. From when I was researching the 3650 it seemed like some people loved them and some people did not. I think they are supposed to be pretty strong, but like any trans they do have their weak points. Of course you have the issues with getting a working speedo. In the end I think I finally have just decided to go with a TKX when the time comes.
    '89 XR-7 5 Speed
    '95 SC 5 Speed
    '97 Thunderbird
    '85 Ford LTD Squire
    Barboursville, WV
    I believe I will be going the tkx route in one of my cars, as well.
    Repair parts can add up quickly in any transmission... Next thing you know you coulda bought a new TKX for what you have into an old outdated transmission..
