Results 1 to 7 of 7
    Default Bushings in my clutch and brake linkage...
    My brake/clutch pedal assembly, from my 83 is out of the car for painting and maintenance....
    I want to replace the nylon bushings where the clutch and brake pedal pivot...
    While the larger clutch bushings seem to be available ( and are advertised to fit both brake and clutch) I can't seem to find the smaller ones I need for the brake....
    Anyone have any leads on to where I can find these???
    Did this change in 87, to incorporate the same size bushings for both pedals???
    Thanks for any help here......
    This is what I have used in the past.
    https://www.npdlink.com/product/bush.../104376/150128
    I will order a set of those and see what they fit, either the clutch or brake.... As i said, my bushings are different sized in my 83 pedal assembly
    This kit appears to have pedal bushings for more than one shaft diameter.
    Don't know if that's right for what you need though!
    https://www.americanmuscle.com/musta...ngs-74016.html
    Thank you, that looks like what I am looking for...
    I purchased a set of these and decided my stock ones were better quality.... thicker and a different material.... I lubed up the stock ones and reused them...... Just sayin......
    You're welcome. Let us know if they work for ya.....
