Trying to diagnose where oil consumption comes from, suspect the valve stem seals.
Second issue is that cylinders 2,3 and 7 don't fire.
Lifted the passenger side valve cover. Everything looks and moves good. (Let it run to check the rockers movement.)
Put cover back on.
Then noticed the hose on the passenger valve cover sucking lots of air, while the pcv valve was disconnected from the vacuum hose going to bottom of the throttle body.
Planning to lift the RPM airgap manifold. Suspect there is a leak path from the intake side to the side that closes of the engine valley.
Anyone that has had a similar issue?
Thanks in advance,
Hans.
Verstuurd vanaf mijn CPH2219 met Tapatalk
