Results 1 to 7 of 7
    Default 4 lug drum conversion to a 5 lug disc
    This has probably already answered on here especially with the sticky post on the 5 lug but I'm a bit lost on that post so... I was wondering if I could just use one of the pre-existing 87-93 5 lug conversion kits from LMR/CJ or if I should/have to stick with the drums on the rear
    Edit: I have a 84 lx convertible with a v6 in it
    Here is the link to the previously mentioned kit
    Rear axle 5 lug conversion & drum kit 79-93 https://lmr.com/item/LRS-1126K/79-93...-Axle-Drum-Kit
    Rear axle 5 lug conversion 87-93 https://lmr.com/item/LRS-4234K/1987-...Conversion-Kit
    Cobra rear axle 5 lug conversion https://lmr.com/item/LRS-4234CB-K/Mu...Conversion-Kit
    I used North Race Cars kit and am very happy with it
    79 Zephyr, 4v/4r70w swap, with team z front and rear suspension, 8.8 and upgraded brakes and coil overs.
    Thank you I'll keep that company in mind when it comes time for to replace the rear end. Question did you have to do anything with the hard lines themselves when modding your car or because the kit includes soft cables you didn't need to
    You cannot use an 87-93 5 lug kit without first swapping front spindles to [87-93V8] or [82-83 Continental/84-86 SVO]. The Continental/SVO spindle requires an SN95 to SVO balljoint adapter and SN95 balljoints
    Your existing struts will work but require a pair of 1/8” thick spacers often found in strut kits.
    Your other option for 5 lug with four eyed fox spindles is rotors for a 1983 Ranger 2.0 RWD. They use the same bearings and seals. They require a different dust cap
    A 245/45/17 tire on a 94-95 17x8.5 Tribar rim will fit in front with the ranger rotor. I suggest a 1/8 wheel spacer for additional strut clearance as the rims often clear but the wheel weights often don’t
    The down side to either of these approaches for the front is the rotor hat height. Many 5 lug wheels fit but you can’t get the center cap on
    -- James
    My four eyed foxes:
    past foxes -
    If you swap to an SVO spindle the strut bolts do not quite align. You have to slot one hole or use a camber bolt or you can’t assemble it
    FEP Supporter Broncojunkie's Avatar
    Barboursville, WV
    Is the ranger rotor bigger than the mustang? Would you need ranger calipers too?
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
