Results 1 to 10 of 10
    Mar 2003
    Lowell, Oregon
    Default Dual plane manifold modification.
    So, gonna prove that I can be an idiot... Maybe? Maybe not?
    When I built my motor and installed the FiTech, I had read a lot of posts indicating that the FiTech 'liked' an open plenum manifold better. That sometimes the dual plane plenum divider 'caused issues'.
    So I cut out most of that divider when I installed it. My assumption was that each cylinder was pulling through the same hole at the top.
    What I've noticed is some plugs (cylinders) running leaner/richer than others. Oddly, my four corners cylinders were one, the four middle were the other. IIRC the middles looked leaner than the corners.
    Can taking the divider piece out of a dual plane manifold do this?
    Manifold is an Edelbrock 289/302 Performer (yes, I should have gone with at least the RPM or a Stealth probably).
    Interesting, I heard all that stuff about tbi and dual plane as well. I would say the surgery could cause your issue. On cfi there were real problems with the stock manifold (pos) and lean cylinders but that was due to the butterflies on the carb biasing the flow away from some cylinders, particularly at WOT. I did a little grinding on my throttle body and fixed that but I suspect with my performer intake the bias wouldn't be as bad as the old truck 2 barrel manifold that came stock. It doesn't sound like you lean cylinders match a specific plane so I bet the missing septum or whatever the call it could be the issue.
    For what it's worth, I have never heard of this problem with cfi and that is fundamentally the same as a sniper or fitech so I wonder how much reality there is to the concern. I wish engine masters would do a test on it.
    Would the RPM manifold even fit under the hood ?
    Mar 2003
    Lowell, Oregon
    Yes, with a drop base filter housing an RPM would fit.
    My thought was that if all runners pull from a common center it wouldn't be a problem. Hence my doing it.
    But, I assume (oh god, there I go again) that a single plane manifold has runners of differing lengths compared to a dual plane, so that might be the problem?
    The car seems to run well. Power feels great, economy is what I'd expect (17-22 mpg mixed hwy/town). But those plug readings... Perhaps I will pull them and see how they look again. I am running one heat range hotter that what was 'recommended' for the AL heads (RY13C?) with no detonation or anything, probably 13* initial with a vac dizzy with the screw inside the vac housing thing close to the max performance wise. I may throw the 'recommended' plugs (above) in and see if anything changes. But the plug won't change a result cyl to cyl.
    I had the hotter plugs in the corners, cooler on the middle 4, because of the apparent differences in mixtures.
    Nov 2004
    Chas. SC
    I've read somewhere that a dual plane will work fine as you modified it. I will do some digging to see where I saw it. If I remember correctly there was a discussion on how much of the separator to remove. I think it ended up being trial and error on a dyno but there should be something about what they settled on.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Nov 2004
    Chas. SC
    Here you go. Start at about minute 17 for the details.
    https://www.youtube.com/watch?v=M2u7d8kajVI
    Sorry it took me so long. LOL
    Albert Einstein
    Almost "Stock"
    Mar 2003
    Lowell, Oregon
    I will take a look!
    Mar 2003
    Lowell, Oregon
    It would appear, based on that (and my previous thought pattern) that cutting out that divider did no harm at all.
    Maybe I just won't worry about those plug readings
    It runs good. It makes good power. It gets decent mileage.
    I might try the cooler/recommended plugs. See if I notice a difference.
    Thanks all!
    Jul 2009
    Chicago, south subs
    Fords have that long runner/short runner thing going on. The 4 corner runners vs the 4 middle runners. I think fuel distribution issues are a fact of life with this set-up. Not to say it isn't tolerable, as long as it doesn't go extreme lean or rich.
    Mar 2003
    Lowell, Oregon
    Right. And it isn't extreme. Just noticeable. Perhaps all my others were that way years past and I just didn't pay this close of attention. Or check them with so few miles on them. I've put under, but near, 5k on it is all.
    Decided just to leave it be. When I get my stroker motor built it will have a different intake manifold anyway.
