Results 1 to 9 of 9
    FEP User Fast_4_Eye's Avatar
    Oct 2021
    Cobourg, Ontario, Canada
    Default Smog Pump Removal?
    I'm not sure if this is a stupid question to ask, but I'd rather ask and not screw my car up.
    So I have been running an off road H pipe on my car for a few months and left the stock air/smog pump on the car as I really had no need to remove it. I have been wanting to but haven't really gotten the chance. Anyways, I installed new factory pullies on my car and noticed I needed a new belt so I've been considering bypassing the smog pump.
    If I bypass the smog pump, can I run the shorter belt and leave the smog pump in place until I get a chance to remove everything? Or should I wait until I can remove the physical pump before bypassing it. I only want to buy one belt, not one for now and another in 2 weeks.
    The car is also my DD so I need it running asap so hopefully I can buy a new belt by the end of tomorrow.
    Daniel
    So you are not running downstream air to a cat? If not then I would just get a smog pump delete pulley. Others will know if you have clearance issues leaving the pump in and running the shorter belt. I find over the long haul being able to just put on stuff that was meant for the car easier. Particularly after some of the mods pile up. My gt40s take a different plug than the stock heads and nearly every time I buy plugs I forget about that...
    Maximum Motorsports caster/camber plates and strut tower brace, 3.73 rear.
    Nov 2004
    Chas. SC
    I put a smaller belt on about 7 years ago and left the pump in place. Never had an issue.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Oct 2021
    Quote Originally Posted by gt4494 View Post
    Thank you, I'll be going on my lunch at school and buying a couple belts to test fit tonight, and return tomorrow.
    Oct 2021
    I get it, I just want to limit moving parts that can go bad thats all, so for me doing a shorter belt is better than an idler pulley since I need a new belt anyways.
    Jul 2010
    Houston (Clear Lake), Texas
    I always just gut the pump and leave it in place to do nothing except provide a pulley for the belt.
    HAD
    HAVE
    Nov 2004
    Chas. SC
    Quote Originally Posted by Fast_4_Eye View Post
    The belt I ended up using was a little tight on initial install but have yet to have any issues. I forgot what length it is but use the string trick to get the size..
    Albert Einstein
    Almost "Stock"
    Oct 2021
    With my pullies I have a crank underdrive and then a water pump and alternator overdrive so all 3 pullies are smaller than stock (1993 Cobra pullies from LMR). My car has no A/C from factory and I bypassed the smog so with the power steering where A/C would be, I was able to fit a 71.5" belt on there, could definitely get away with a 72" but they were out of stock and tbh I think the 71.5" fits better and will allow for proper belt stretch and whatnot.
    Nov 2004
    Chas. SC
    Sounds great!!
    Albert Einstein
    Almost "Stock"
