Results 1 to 3 of 3
    Default Early AC line to 87 AC compressor? Anyone done it?
    Hey guys. Quick AC question. I have a 79, AC equipped car, pictured below. Im swapping in a 87 and up motor and accessories. Obviously the lines are different from era to era but, has anyone adapted the early fox dryer setup to the newer condenser and compressor. Pics below! Thanks for any help. I have thisName:  14915EEF-9B65-4D88-A9D1-EFFDE819A67C.jpeg
Size:  130.1 KB and im looking to use this compressor Name:  9F48B550-0AC3-4641-9015-1E424EB7E669.jpeg
    1982 Mercury Capri Godzilla swapped/T56
    1984 Mercury Capri RS T-Top, 4.6 Terminator Whipple
    1979 Mercury Capri RS Turbo, SVO powertrain..(under construction)
    1979 Mercury Capri RS Bright Yellow
    1983 Mercury Capri RS 21k original miles
    1985 Mercury Capri Mclaren Convertible
    Check out my youtube channel for Four Eyed Fox stuff!
    https://youtube.com/@401foxbody
    I would think a shop that does hydraulic hoses should be able to make up a hose with the ends you need.
    steve
    Just my .02 your opinion may differ.
    The early H valve A/C systems can be very difficult to get to cool properly even when using the original R12 freon. If you plan on using R134a, I would highly recommend you swap the entire under dash unit out for the later model orifice tube system. That will allow you to use off the shelve A/C lines and parts without having to have custom lines made, etc.
    I did this to my 79 PC, although mine was original a heat only car, but I swapped in a 1986 underdash unit and control head and everything looks and works really well even with R134a freon. There are some minor differences in boxes through the years and the control units vary depending on year model, but you should be able to make your existing control unit work with any of the later models HVAC boxes with little to no changes. Good Luck!
