So I did this on impulse mostly looking for any carbed 5 spd. Never been a ford guy, though I’ve had some sweet ones I’ve just never worked on them or owned them long. This on the other hand is a horse of a different color having problem after problem. Hooray!
The trip picking it up with my dad is a whole story by itself.
she’s a 1983 gt 5.0 hatchback 5 spd. Black on black. Sunroof, ac car. No power windows or locks
117k miles but the thing is she’s been in hibernation since 1999 in dry barn storage. That means mice. I vacuumed 2 gallons of **** at least 3 mummies. They were in the headliner, steering column. You name it the the were there. Even the air filter
Luckily the gas tank was dry
first things first. Hear it run. Used carb put on, Gas in the tank,Battery in, key in, ignition to crank.
well it did fire for a second as soon as I let the key go nothing. Turns out mice piss isn’t good for electrical connections. After countless hours of pulling my hair out,I cleaned the ignition switch(electric) with some wd40 and worked it real good. Tada, it actually runs. Crappy but it runs.
side note do not buy eBay ignition switches it did the exact same thing as the original was before I cleaned it.
some new spark plugs helped quite a bit but why couldn’t I put it in gear when it’s running? Cause the the clutch actually rusted to the flywheel. It was a simple fix, just started it in gear with the clutch pressed. Okay cool. Do I dare drive it? No plates, no title. Mind you I live on top the steepest hill around. Hell yeah I did. Just a few blocks but found the brakes didn’t exist, I had no brake lights either. What else were those mice messing up? They pissed all over the fuse box but that comes in later.
Anyway I know she runs so I can dig in literally. Once the interior was out and washed and vacuumed I looked at the floor pan that needed a little work. (I’d include pics but it keeps failing) anyway I patched it up real nice with my $95 harbor freight flux core welder, it wasn’t easy or fun as I kept burning through. But I managed to make it nice with little to no pinholes I had 4 pieces I welded in the biggest being maybe 2.5”x2.5” the smallest being about the size of a sharpie cap.over all not bad. so what I did next was put down some rubberized roof coating to avoid the tin sound and prevent any rust. After my subframe connectors are in I’ll coat the bottom with some bed liner.
On to electrical. So I’m getting 11.9 volts at the brake switch on the hot side. If I hit the pedal or jump the connection it drops to 0.
man what a headache. I traced harness to lights looked good and tested good as well. Long story short . It was the fuse which I did check and sprayed with wd40 had built up so much rock hard mouse piss that it looked like a metal. That’s ridiculous in the midst of the wiring deal I also replaced the brake hoses and pumped all new fluid through the system. Luckily the master wasn’t to crusty inside and seemed to smooth out quite nice. I also put new hatch struts on as well as managed to find some nice shape prime rims and some new shoes to replace the cracked and constant deflating tires, changed the oil. I also touched up the front end painted the grill and the bumper cover strip. The car needs paint but a huge improvement if you ask me
so yesterday I buttoned up the interior except a few pieces(where did all the correct screws go?) with some new lights in the gauges and corner lights.
so I’m on to tuning as of now but I have a huge problem. The damn distributor will not budge, I pulled the bolt and clamp completely out but nothing. I even beat on it with a log and socket extension after soaking it with wd40 and still she hates me. According to the vacuum gauge I may have an intake leak which might be as it’s an edelbrock so not stock. The only other mods I could see are a b&m short throw shifter, and a tape deck. It’s like a time capsule. I did drive it since the brakes needed testing, very short very sweet. Miss the v8
the exhaust was completely stock and completely plugged until I cut the mufflers off there was nothing coming from the back of the car so I’ll need a new cross member and a full exhaust and haven’t bought subframe connectors either.
I still need to buy some plug wires as that maybe the bounce in the gauge but I doubt it. The next nice day I’ll be taking the smog pump off and probably the ac as well.
thanks for having me here hope you can help me if I need it I got nothing at corral.
