Hi All,
Im new to the fox body, with a 1982 Capri RS, 5.0L , 5 spd manual, I purchased a short time ago.
Prior owner(s) somewhere along the way built up the engine, but the car still has the 7.5 rear.
The person I got the car from did not know anything about the rear diff.
Id like to change the 7.5, and swap in the beefier 8.8, but also have other reasons for this.
- add rear disk brakes
- convert the wheels to 5 lug
- ensure limited slip diff happens (I'm not sure if the current 7.5 has it or not, as i've not pulled the cover ... yet)
I have read already in other threads on this subject where 86-93 mustang 8.8 will swap out directly. No modifications required. A 94 - 98, will work but may require using the axles from the 7.5, and maybe a few other suspension pieces.
So are there specific donor cars that I could source such an 8.8 rear end that that would meet the requirements, yet install without a lot of modifications to the 8.8 to mount in the 82 Capri?
Any details would be much appreciated.
