Results 1 to 2 of 2
    Default Clutch Pedal question
    As I was installing my new Steeda Clutch pedal quadrant and adjustable cable, I noticed that I had about 3/8 of an inch of thread showing where the clutch pedal bolts on to the clutch/brake pedal assembly, my question is, can you space the clutch pedal out so that there is more room between the two pedals? Sometimes it seem that there is not enough room between them and I get my shoes caught on the them. Thanks for any help!
    1986 ACS McLaren Capri
    1971 Mustang
    1968 F100
    Whitestone, NY
    The shaft the clutch pedal bolts onto has a square profile to fit the square hole on the clutch pedal. Spacing the clutch pedal out will mean that the clutch pedal will not activate your clutch quadrant. There is a clutch pedal height adjuster kit from maximum motorsports that will gain you roughly 1/4 inch (as it spaces the pedal out some and allows one to play with pedal height).
    Simple answer to your question is no.
