no
no
The stock AOD in my '86 will not shift into OD at WOT. The OD is the weakest link in most any stock AOD and Ford knows this, hence the lockout.
Sounds like you are having the beginnings of terminal OD failure
If not that... then it's the 2-piece input shaft and the problems you described are your tranny's failure to lock up the converter.
--John
One Owner '86 GT - Exhaust, Gears, Basics, otherwise stock.
NOS - It's an abbrevation, not a word.
