Results 1 to 25 of 29
    FEP Member Hans's Avatar
    Jun 2008
    the Netherlands
    Default Car is puzzling me
    Why does the temperature needle point constantly at the max "normal" limit and overheat at the traffic light, in the cold mornings. And runs at the normal lower temperature and doesn't overheat when the outside temperature in sunny afternoon is much higher . Commuting 30 miles both ways.
    I remedy the overheating by revving the engine to 4000 RPM and the temperature drops again.
    Thermostat is probably causing this I think. Or it's jinxed .
    Verstuurd vanaf mijn CPH2219 met Tapatalk
    Nov 2004
    Chas. SC
    I vote thermostat!
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Also check the thermal clutch. They can fail in various ways.
    When the engine is running warm/hot, park the car, with the hood up, window down, door closed, shut off the engine, and quickly look at the fan blades. The fan should be stopped, or stopped in another ~second. The fan should also have noticeable drag.
    Also, make sure that the radiator, and AC condenser are not blocked. If they are, the fan may be drawing air in from under the car. That prevents the radiator from cooling, and would also make the fan clutch colder, and therefore slip more (lot of slip when cold, little slip when hot).
    Good Luck!
    Jun 2008
    the Netherlands
    Thanks for the tips.
    This weekend I dig in to it.
    If the heater hoses are hot, there can't be a big air bubble around the thermostat, right? (Since the heater hose connects there.)
    You might also want to rule out an alternator or IVR issue. My car seemed to run hot until I turned on the seat heaters. The increased alternator output corrected the gauge readings.
    On another note, my 67 Tbird was running hot at speeds over 65 mph. Turns out it was never shifting into 3 rd gear. Lol.
    Nov 2004
    Chas. SC
    My '84 started running hot but the gauge was right where it should be. didn't notice it till I had water coming out the tailpipes driving on the interstate Turned out the sensor went bad and it cost me a set of warped heads.
    I just recommend figuring it out sooner then later!.
    Albert Einstein
    Almost "Stock"
    I have found the thermostats produced today are incredibly badly made. I think I have gone through 4 or 5 in the last 7 years. Sometimes only lasting a few months. Fan is easy to check, so is the air flow. You could even pull the coolant temp sensor and check that too. Even a disconnected egr can cause heat issues. But I bet on a craptastic thermostat.
    Jun 2008
    the Netherlands
    How can I test the coolant temperature sensor?
    Should it have a certain resistance value perhaps?
    Maybe I can purchase a new one from Rockauto to compare the two.
    I will check the alternator voltage output too just to be sure it doesn't spike on occasion.
    How do you guys burp the upper radiator hose? Any trick for that. (Don't think there's much air in it though.)
    I do have a new thermostat, housing and the little elbow hose in house fortunately.
    I keep spares because I have to have everything flown in.
    And what do you know: it's snowing since yesterday. Not comfy for a front yard wrencher.
    What I was going to suggest is if you have a hotplate, pull the temp sensor and stick it heated water, check to see at what temp your gauge is reading where on the dash. If it bounces around you know something is up but each of these damn things appear to read differently, would be good to know what the actual temp is at points on your gauge. When I was troubleshooting I installed an aftermarket coolant temp gauge that used an ether line to monitor real coolant temps. Not worth that much trouble. Eventually I pinched the line during a race and now it's garbage.
    Burping most people do by filling with the front end jacked up as high as possible. That said, it has never been an issue with my 84. That cool little expansion tank thing works really well for allowing the air out and sucking fluid back in.
    Nov 2004
    Chas. SC
    I've never done it this way but it should work. Only difference is the FORD only has one wire so the second "wire" is the body of the unit or ground.
    https://itstillruns.com/test-sensor-...l-7927898.html
    Albert Einstein
    Almost "Stock"
    Oct 2017
    south-central WY
    If you don't have a hot plate, you could wrap the sensor and a thermometer in a heating pad. Or is it only us old guys who have heating pads?
    Jun 2008
    the Netherlands
    Top - cheap Summit, middle - replaced last year, bottom-currently used Stant thermostat.
    The first two open the same, before water boils. Stant is slower. Also the opening remains far smaller because of the valve that has an edge inside the seat where the others are almost flat.
    Then the Stant thermostat closes first again.
    Another observation: the Summit thermostat valve opens and moves sideways. Not straight. But when it closes it centers itself on the seat.
    make sure your pressure cap is good and no leaks
    fan clutch could be faulty
    Water pump impellers do go bad sometimes
    Radiators get clogged and need to be cleaned/reconditioned at times
    thermostats are hit and miss usually
    would get the 190 degree Motorcraft high flow thermostat
    It was originally designed for the EFI 386 series (big block 460) F series trucks
    Motorcraft RT-1067-A
    Is this carbed or injected?
    Jun 2008
    the Netherlands
    The original 79 5.0 engine. Carbed there fore.
    Ok, you could try a different thermostat temp without problems. On the fuel injected versions you need to be careful with cooler thermostats.
    Jun 2008
    the Netherlands
    Always something going to cause an issue:
    I purchased a replacement thermostat housing. Unfortunately the flange does not seal against my Airgap intake manifold.
    The Felpro gaskets do fit on the original housing (second picture), but not on the Dorman housing. The heater passage is shifted. I didn't notice because the Dorman housing came with its own gasket.
    I found out after reinstall of all parts on the engine when refilling the coolant... Poured out almost as fast as I could fill the radiator .
    The bottom piece of the sealing edge on the heater passage is severely pitted. (On the original housing.)
    I want to fix that with JB Weld or a similar brand paste.
    Is there a better way to do that?
    Regards, Hans.
    Mar 2003
    Lowell, Oregon
    If you're talking about a sealing surface I would use rtv gray over JB weld myself.
    I had a similar issue - bought a higher quality T-Stat which happened to have a slightly thicker flange so it would not seal. I ended up rtv -ing two gaskets together to create a thicker gasket. Now it's perfectly sealed.
    Jun 2008
    the Netherlands
    See the pics please.
    The edge of the port is almost gone.
    I think filling up the rust pit in the edge of the port will reduce the likelihood of leaks later on.
    I do agree on using RTV in addition to the Felpro gasket.
    It remained leek free like that for nine years.
    Mar 2003
    Lowell, Oregon
    I used a housing from LMR and one sealing edge is super narrow, maybe 1/16"? It didn't line up exactly, but I had the part for too long to try and return it. No leaks. In fact the bypass tube is also offset some. But enough gets through to run properly.
    I do agree it is good to try and reduce the corrosion. But a new housing is only what, around $25 from them.
    Just a thought.
    Jun 2008
    the Netherlands
    I found more people having the issue that on the Edelbrock 7521 manifold many of the thermostat housings don't fit.
    The bypass hole position is different.
    The old housings fit . The current ones not.
    Probably easier to fix my 79 housing. That has worked on said manifold 9 years without leaking. Despite the pitted edge.
    Jun 2008
    the Netherlands
    Just a thought.
    The LMR housing seems the same as the one that I got here. That doesn't fit.
    Jun 2008
    the Netherlands
    First picture: See the kit that didn't touch the Edelbrock 7521 manifold flange at the bottom of the heater passage.
    Picture Two:
    The original 79 housing is dimensionally different. Distance between bypass port and mounting hole is 7mm less than of the replacement housing.
    So the old part goes back in. Including the Sems capscrews. I'm a sucker for original parts. The hoses are from 1978 too. Still okay.
    I think I discovered the cause of overheating. The thermostat was mounted backwards. The copper cylinder/ wax body pointed to the radiator hose. Should be at the engine side.
    Nov 2004
    Chas. SC
    Good catch!! That will definitely cause issues. The pointed end is where the bimetal spring is that opens the thermostat up. In the hose it doesn't get hot water circulation so it can't open. Only heat it would see is from the intake metal to housing metal.
    Albert Einstein
    Almost "Stock"
    Nice catch.
