Results 1 to 15 of 15
    Sep 2010
    Lexington, MA
    Default Steering Problems...
    Does anybody know why the steering wheel would travel about 4-5" when the car is turned off, very 'sloppy.' Do I need a new steering box? Thanks in advance
    Jul 2010
    Houston (Clear Lake), Texas
    Rag joint, steering gear box, etc.
    HAD
    HAVE
    Mar 2017
    middleboro massachusetts
    tilt wheel mechanism?i just went through the same issue in my 85.had to find another column.wheel would move a inch or more in each direction before my wheels moved.
    Check your inner and outer tie rod ends too.
    Sounds like a rag joint to me. Order 1 for a 1969 Boss 302. Ford has been parts bin engineering for decades and it was also used in the SVOs.
    steve
    Sep 2010
    Lexington, MA
    Quote Originally Posted by teal95 View Post
    sounds like a rag joint to me. Order 1 for a 1969 boss 302. Ford has been parts bin engineering for decades and it was also used in the svos.
    Steve
    'April Fools!?'
    On an aside, this '83 T-top notch has something totally surprising; FACT0RY manual steering
    Nov 2004
    Chas. SC
    'April Fools!?'
    All the more reason to check the Rag Joint. :P
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    Sep 2010
    Lexington, MA
    Ah! Incredibly this car has only 78K orig mi. I'm looking at the MSRP right now; evidently was $6727, but as delivered $8351. Think with Financing, it was $10K out the door.
    Nov 2004
    Chas. SC
    Yep and in 2004 I paid $1750 for my DD '84 GT350. I could sell it anytime I want for $5 - 10k. and it still has its tired original paint. and I'm the 2nd owner with all paperwork including sticker.
    Albert Einstein
    Almost "Stock"
    Sep 2010
    Lexington, MA
    Oh sweet! With my '83 GT I am the 2nd owner as well. Question, were you near USC? A buddy of mine from High School attended USC, and also my cousin was stationed at nearby Ft. Jackson.
    Nov 2004
    Chas. SC
    US is in Columbia and that is about 1.5 hours away. We are on the coast. We have Joint Base Chas. here. Just A.F. and Navy.
    Albert Einstein
    Almost "Stock"
    Barboursville, WV
    I installed a flaming river manual rack and steering shaft in my pace car. Control arms/bushings/ball joints, rack bushings, tie rod ends, struts, and pretty much everything associated is new. It's been installed for a few years now, but probably less than 200 miles on them. Steering is now very loose. I'm not going to drive it until I figure out what's wrong. Looking like it's the flaming river shaft at fault but I just haven't had the time to start digging into it. I know I didn't care for the design at all, but went ahead and installed anyway. Bolts still tight and I used red loctite. I think from now on, I'll just modify a factory shaft by welding on a u-joint in place of the rag joint. I have the parts on hand for manual and power steering shaft. The u-joints are available from Summit and several other places.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Barboursville, WV
    Sep 2010
    Lexington, MA
    Good to know. Thanks friend!
    Nice fix. I’m all about diy and saving $ I will keep this in mind.
    and yes to the harbor freight welder. I have the same 1, just wish it could use smaller wire for body work.
