Results 1 to 2 of 2
Thread: Mechanical 85
    Default Mechanical 85
    Just updating the latest pictures of my restoration, slow progress in obtaining parts and finally received my brake and power steering parts as well as headlight header panel top and lower brackets. Researched a lot of low millage pictures of 1985 mustangs to ensure I had the correct bolts etc. still waiting on the Brake proportioning valve as I did upgrade the rear brake drums to Disc. The front brakes I rebuilt the calipers, new flexible lines pads and fitted new disc with new bearings and grease caps. The other problem I have is once you get down to the small parts that you need for the restoration is that you have to purchase the assembly to get that small part, that starts to get real expensive with added shipping. But Hey who said it was going to be easy to restore a car.
    Man, looking real good.... Your 100% correct on not being easy. Take your time and get it the way you want to be... Good luck.
