Fighting an issue on my 85 GT Saleen clone car
The head lights will turn on if you flash them by pulling back on the dimmer switch but they will not turn on with the headlight switch
When Trey and I last discussed it we thought it was the dimmer/turn signal switch on the column. I swapped in a new one last night and the lights still do not work with the headlight switch
Since the car is a GT and it is a Saleen clone we put an LX front bumper on it and eliminated the fog lights.
Im also battling an issue where the horn does not work and an issue where the engine does not crank with the key when the clutch disengaged. Those seem unrelated but I’m not sure
I’m about ready to tear the dash out and the front fascia off and source a full harness from prestige mustang. This car doesn’t have to be perfect but it needs to be right
