Does anyone know if this will work? I managed to find an LTD LX instrument cluster, but still have the v6 in my car.
Thanks.
Thanks.
84 LTD, 331-10:1, TW170/Exprl Intake, 47 lbs inj/80 mm LMAF, Full Duals, Quarterhorse, Vortech 7PSI, Lentech AOD, 5 lug Mk VII brakes/rear, Eibach Sway bars, Cobra HB (dads ride, but I fix it)
Thanks. I had seen that, but still not sure if it will work. There is no tach wire on my harness, and I'm not sure where to get it from. From the negative side of the ignition coil? Also not sure if it will read a 6 cylinder correctly since it came out of an 8 cylinder car. I don't really care if it's off some since I'm not racing, but don't want to fry it.
Good point, I wasn't even thinking 6 vs 8 cyl. Probably won't read right at all like you said.
But yes, I ran new wire from coil to that connector. I stole a wire from that connector off a parts
car and soldered another wire to it to go to coil. So the connector still works/looks factory like, anyway.
