Results 1 to 8 of 8
Thread: Amp pull switch
    Default Amp pull switch
    SOLD Thanks
    Forgive my ignorance, but i have never heard of this switch.
    What is its purpose? Was this a stock switch?
    It is to turn the dash-mounted amplifier on and off located below the headlight switch. The amplifier was part of the "Premium Sound System" option. I think this is correct. I ended up with the switch buying a parts lot.
    It's actually located in front of the drivers right knee.
    84 Capri RS Turbo
    USAF 1986-2007 (Ret)
    Thank you!
    I was thinking "amperage" and not "amplifier" lmao
    Whitestone, NY
    The panther platform cars received the full text to avoid any confusion.... "Amplifier Pull"
    Good luck with your sale. I use these switches to manually turn on and off my aftermarket amplifiers.
    Jul 2010
    Houston (Clear Lake), Texas
    Quote Originally Posted by billkandi View Post
    That's what I recall from my ole 82 GT from back in the day. My girlfriend at the time had an 83 which did not have it, but hers was a late 83 with the 5 speed.
    HAD
    HAVE
    FEP Senior Member 9DBlackMagic's Avatar
    Sep 2006
    Antioch, California
    Is this still available
    ~LES~
    157 HP @ 4200 RPM
    240 ft/lb @ 2400 RPM
    "Yeah Baby Feel That Pure Power"
    Capri:
    Is a Mustang With Hips And Class
