Page 3 of 10 FirstFirst 12345 ... LastLast
Results 51 to 75 of 236
  1. #51
    Picked up some new carb studs and a carb base gasket. Got a 1" phenolic spacer on the way, and I want to be ready for it. Here's hoping 2-1/2 studs are long enough but not TOO long, and I can brainstorm around that weird cutout in the gasket.
    Edit: 1" was just too much, so now I got that cluttering up my box of parts. Live and learn, I guess.
    2020 Royal Enfield Continental GT
    2005 Volvo S60 2.5T AWD
    2003 Royal Enfield Bullet 500
    1985 Ford Mustang GT
  2. #52
    Default 2.3 intake work
    Noticed other day during routine under hood check, one intake manifold to cyl head bolt was missing.
    #1 intake runner top bolt to cyl head.
    Will never know why it was missing and what happened.
    Needed another bolt. Ford shop manual said M8 1.75 30mm.
    Can you believe quickly found a used oe flange bolt in the parts box that fit exactly?
    Maybe one day the missing bolt was found laying loose by the dist, saved, but origin was unknown till now?
    Looks like the others. The patina matched, fit a 13mm socket like the others.
    One of those rare repairs that defiantly justifies saving a few good used take off parts like factory fasteners.
    Was easy to install. Straight shot using a socket extension.
    Starting to prep replacement 2.3 n/a intake manifold.
    Need connections for vac. PCV, brake booster, vac gauge, check clearances/routing around components.
    Order open style 1/2" aluminum carb spacer.
    Work out intake coolant flow, which is configured differently.
    May use an intake gasket from 84-85 LTD/Marquis 2.3 LPG engines, which block off the intake water at the cyl head.
    Do everything ahead of time before removing current carb turbo manifold and turbo assy.
    Can hardly wait!
    Name:  intake na vac taps 40122 3030.JPG
  3. #53
    Feb 2018
    Saskatchewan, Canada
    Finally sucked it up and removed my tie rods, front springs and a arms. Been putting it off due to being hesitant to remove springs by myself for the first time. Went pretty good and everything came out with out any major problems. Now for some paint and installing new caster camber plates, arms, springs and tie rods.
    Mustangs
    84.5 Gt T-top
    85 Gt
  4. #54
    Ordered a cheap single din Android head unit with touch screen. Plan on running Shadow Dash on it, stereo and gauges wrapped up in one unit.
    Jeremiah
    1986 Mustang GT 5spd, 3.27's
    1993 Volvo 240 Wagon
    LQ4 w/cam. 4L80E w/shift kit and Circle D 3200 Stall. Nearly Finished
  5. #55
    Jul 2009
    Montreal, Quebec, Canada
    Talked to it. It's coming along slowly but surely.
    Crossing fingers but primer next week.Name:  PXL_20220408_152449418.jpg
Size:  124.2 KBName:  PXL_20220408_152428319.jpg
    Sent from my Pixel 6 using Tapatalk
    1985 Mustang Canadian Cobra
    It ain't Pretty but it doesn't care
  6. #56
    I pulled it out of storage last Sat
  7. #57
    Pressure washing the Capri’s carpet.
    84 Capri RS Turbo
    USAF 1986-2007 (Ret)
  8. #58
    I also used the pressure washer to remove some 30+ year old tint.
    84 Capri RS Turbo
  9. #59
    Finally put the 306 in the 82 Capri BMName:  20220409_155845.jpg
Size:  119.3 KBName:  20220409_154101.jpg
    Sent from my SM-A326U using Tapatalk
    82 Capri BM, 84 Mustang Gt, 88 T-Bird TC, 93 Mustang
  10. #60
    85 Saleen build ….. fire in the hole! Whoomah !
  11. #61
    85 Saleen build Ö.. fire in the hole! Whoomah !
    Ive been following that build, I also saw your car in person when it was at Trey's shop in Texas
  12. #62
    Nov 2004
    Leather wrapped my steering wheels. One on the right is the stock sport wheel that came with the car. The cover gives a nice feel to the wheel, but not quite a thick as a factory wrapped wheel.
    The one on the left is a factory leather wrapped sport wheel that covered with another leather wrap. I like the feeling of the factory leather wheel as thickness of this wheel feels more like a modern wheel. With the added leather, it is close to the thickness of my 2017's steering wheel.
  13. #63
    I installed a set of RMS LED headlights and a set of Red Line hood struts.
    All I need to do is swap out my Borla mufflers for a set of Spintech's and my car is done for cruise season.
  14. #64
    Barboursville, WV
    Quote Originally Posted by Mustang Marty View Post
    Fantastic work! If a guy wanted to learn to do this, where would he go for a how-to?
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
  15. #65
    new battery, oil change and state inspection.
  16. #66
    installed Steeda adjustable clutch cable, firewall adjuster and Billet Alum quadrant on the 86 Capri. Quadrant was a ton of fun!!!
    1986 ACS McLaren Capri
    1971 Mustang
    1968 F100
  17. #67
    Jul 2004
    Montebello, CA
    I finally got my Capri to the Fab Ford Show a few days ago, missed last years show due to my motor failing and then waiting 9 months for the rebuildName:  thumbnail (1).jpg
    2021 Ford Explorer ST (DD) 1986 Capri 5.0 Silver/Red
    Past 4 eyes-
    U.S. NAVY 1980-2009
  18. #68
    Mocked up the touch screen, hope I have time tomorrow to install it. No cutting/trimming required, single din unit.
    Jeremiah
  19. #69
    I had to massage the drivers side shock tower with a BFH to install a 93 brake booster.
  20. #70
    Sep 2010
    Lexington, MA
    Getting ready to do an Oil Change & a Wash/Wax can't wait
  21. #71
    Got the dash harness out of the Capri yesterday. Now to inspect, repair, and re-wrap. Now to fit it and tweak to the replacement dash hull.
    84 Capri RS Turbo
  22. #72
    Pulled all of the engine/trans wiring out of the car and started laying the Holley harnesses. I'm not super happy with the fit, going to call Holley tomorrow and see if i can send mine back for some unterminated harnesses.
  23. #73
    Feb 2018
    Sandblasted my spindles at work during the week and spray painted them today with 3 coats of vht roll bar and chassis paint. Much, much better.
    Mustangs
    84.5 Gt T-top
    85 Gt
  24. #74
    That roll bar & chassis paint is some good stufff always worked great for me
  25. #75
    Feb 2018
    ya man, I love it. Itís my go to for sure. Stuffs getting expensive now though lol I paid 25 bucks(cad) a can. Itís crazy
    Mustangs
    84.5 Gt T-top
    85 Gt
