Results 1 to 3 of 3
    Default Resealing Cowl Halves
    I took the top cover to the cowl off of my 1984 GT to make some rust repairs. From the factory there's a seam sealer between the two pieces and I'm wondering what product I should use during reassembly.
    I plan to paint everything with an epoxy primer and top it with an enamel.
    Forgot to mention I have a new tube of 3M Dynatron grey I bought planning to use on panel seams but I'm not sure if that's the product to use when putting the cowl back together and spot welding.
    I am no longer in the autobody industry, so I am sure there are more options out there than I am aware of. I am sure 3M/Duramix has an option, but I just don't know any part numbers for you. In my experience most of the sealants are bonding adhesives that allow resistance welding before they cure. I have used the Lord Fusor brand for several years now and just recently on my wide body conversion for exactly what you are doing with excellent results.
    https://www.lord.com/products-and-so...nding-products
    You just have to pick the size and work time you need for your project. The large tubes require a special caulk gun that isn't crazy expensive, but still an added expense if you don't need it for future projects. The smaller tubes use a smaller gun that is much cheaper from what I recall. I buy the larger tubes as its a better deal and I bought the gun years ago for all my projects. Hope that helps and I am sure others will post some additional options. Good Luck!
