Results 26 to 50 of 73
Thread: SVO EH Build
  1. #26
    Nov 2011
    Alberta, Canada
    I’ve got some questions in the 2.3 specific forum. If any of you have any ideas, please let me know
  2. #27
    Nov 2011
    Alberta, Canada
    Engine assembly
  3. #28
    Nov 2011
    Alberta, Canada
    I have an idea to make the air compressor work. I’ll post pictures as I progress on it.
  4. #29
    Nov 2011
    Alberta, Canada
    I installed the compressor in today. I posted details in the 2.3 section.
  5. #30
    Jan 2006
    Western MA
    Looking good. Sorry I wasn't able to provide assistance to your tech question....
    1986 SVO Mustang - 1C
  6. #31
    Aug 2003
    Villa Park, IL
    Patrick - Looks great. When you're done, do you want to do another SVO? LOL Mike
  7. #32
    Nov 2011
    Alberta, Canada
    In a word Mike, NO.
    Having said that, if anyone knows how to install the front cover on the compressor, please let me know.
    Patrick
  8. #33
    Quote Originally Posted by cougman67 View Post
    In a word Mike, NO.
    Patrick
    I have not messed with that specific compressor, but most are just pressed on and retained by a front bolt or nut if the shaft is threaded. You should be able to rent the tools are your local auto parts store. Generally very similar in practice to installing the pulley on a PS pump. I might be wrong, but pretty sure that is how it should work on that one too. Good Luck!
  9. #34
    Jan 2006
    Western MA
    Does this diagram help?
  10. #35
    Nov 2011
    Alberta, Canada
    Thanks for the diagram. It helps a little. The hub rubs against the clutch and I believe I either need more spacers or a different one.
    I’ll call Ranchu next week to find out what my options are.
Size:  100.3 KBName:  75261CD3-0F1B-47A3-9C80-F3B516FC267E.jpeg
  11. #36
    Nov 2011
    Alberta, Canada
    A little weekend update. I installed the engine without the transmission. That will come later this week or weekend. I purchased the third/cougar engine mounts and hope their in right.
  12. #37
    Nov 2011
    Alberta, Canada
    My friends son came by to help with the install and to learn about engines.
  13. #38
    Jan 2006
    Western MA
    Looking good. As for the AC, you should have about a matchbook space between the hub and clutch. I'm sure there is a more specific clearance spec, but that should get you close enough. Item #8 are the shim(s) that are used to achieve the necessary spacing.
  14. #39
    Nov 2011
    Alberta, Canada
    I spoke to Ranchu and they said I need to purchase a shim kit. Unfortunately they did not know what kit will work. I am going to look for something locally that I can make fit. As for the space, they said 10 to 15 thousands gap.
  15. #40
    Nov 2011
    Alberta, Canada
    Well I hope to install the transmission tomorrow. The old one was rebuilt a few years ago and works well. Notice the hurst shifter.
  16. #41
    Nov 2011
    Alberta, Canada
  17. #42
    Nov 2011
    Alberta, Canada
    Well I managed to install the transmission. It’s difficult without a lift and up only 2’ off the ground. I had to lift it in place and push it in by hand. I have a quick tip for you. If You can’t get it in the last inch, Have someone press the clutch slowly while you’re pushing the transmission in. It’s the second time I’ve done it and it works quite well.
  18. #43
    Jan 2006
    Western MA
    Great progress.
  19. #44
    Nov 2011
    Alberta, Canada
    Well I returned from holidays and got back to work today. I have begun installing the turbo. Yes I wanted to install it before engine installation but the timing didn’t work. I need to find the fitting for the oil inlet line before going much further. You may notice the turbo inlet is 4” in size which is another thing I need to work on.
  20. #45
    Nov 2011
    Alberta, Canada
    Another update. I had to fabricate a bracket support for the VAM. I have a few fit-up issues with the internal wastegate and hope to have it resolved in the next few weeks. The radiator took a bit of work but it seems to work with the factory fan.
Size:  139.7 KBName:  C8576345-53B9-48D9-8BFB-51B945BB7C8B.jpeg
  21. #46
    Nov 2011
    Alberta, Canada
    This weekend I finished the turbo install and began working on the stinger FMIC. I see that it’s too far in front and worried that it’s not going to fit without major mods. The Instructions mentioned I need to move the AC condenser back an inch. Unfortunately, I need to move it back 2”. If anyone had done this install, please contact me and let me know what you did.
  22. #47
    Nov 2011
    Alberta, Canada
    A few more pictures with the nose in place (sort of).
  23. #48
    Aug 2003
    Villa Park, IL
    Nice front mount set up Patrick. Look great.
  24. #49
    Nov 2011
    Alberta, Canada
    I trimmed the air conditioning cooler brackets and modified the upper intercooler brackets to move the Intercooler back.
    Let’s see if it works.
  25. #50
    Nov 2011
    Alberta, Canada
    It’s getting closer now. I’m a little concerned about cutting the headlight panel so I’ll wait for someone who has installed one before making the final cut.
