working on my 1985 Saleen clone.
Trey and I determined that it would be best to remove the accessory light group (fog lamps) from the car since the Saleen fascia and the GT light openings do not line up.
Trey took out all of the fog light related stuff. All of the plugs and wiring related to lights looked to be in great shape . It probably hardly ever saw any use as it still had original to 1985 lights in it. Most of its ~14K were likely all on a race track given its history.
There were some problems with the harness up by the core support that Trey fully addressed when he was preparing to assemble the front of the car.
It has brand new never tested Motorcraft headlight and dimmer switches in it. I have no idea if any of it worked before it was torn down for a heavy redo.
The problem I am having is headlights. I can pull back on the dimmer switch and light up all 4, but I cannot get the headlights to come on low beam or high beam. All of the park lights and tail lights work. The instrument cluster lights work.
Trey and I are figuring it is probably a faulty dimmer switch. I tracked down a new one from Napa but I have not carved out time to install it yet.
I wanted to get some thoughts about the correct switches to use if removing the accessory light group so I have a little more info the next time I'm out in the garage working on it.
Thanks in advance for any replies.
