Results 1 to 11 of 11
Thread: '83 Spare tire
    Default '83 Spare tire
    Hi all,
    Our '83 Mustang still has the original "temporary" spare tire in the trunk wheel well. Never been on the car-never used. It is a B78/14 tire.
    I would like to replace it with something new, and would prefer to have a regular tire. The tire shops are having a hard time finding a tire that will fit in the trunk well. I think it has a 5.5 - 6 inch wide rim.
    So, what are you guys using for a spare tire?
    Most just leave the stock spare in the trunk. Most likely you will have to do some J/Y searching to find a wheel narrow enough to stay under the rear cover. You can look for the 93 Cobra spare tire which is aluminum and 15", but they are getting harder to come by.
    Here is one option. https://www.ebay.com/itm/37360951494...EAAOSw3QVgwWnJ
    Here is another option, but you will need a tire. https://www.ebay.com/itm/18449525101...kAAOSw5d5fjc4o
    Good Luck!
    I have the OEM rim (and tire). I just need to find a new tire.
    Apr 2010
    Portland, Oregon
    Modern equivalent of B78/14 appears to be 175-70/14. tirerack.com and others show several options.
    Mike, Thanks for the reply.
    That tire is a little to fat (cross section). The wheel well is only 6.5 inches deep. But you got me thinking of different tire options. I think a 165/65 R14 or a 175/65 R 14 might work. Gotta check with discount tire & see what the cross section of those tires is.
    Thanks again, Dave
    According to Etrailer.com this is the conversion.
    The modern equivalent of a B78-14 is a 175/75-14 or a 185/70-14
    175/75/14 converts to roughly 6 29/32" section width, 5 3/16" sidewall height, 24 11/32" overall diameter
    185/70/14 converts to roughly 7 5/16" section width, 5 1/8" sidewall height, 24 7/32" overall diameter
    Every tire manufacturer will vary from the above numbers slightly just nature of the beast.
    Quote Originally Posted by 1carguy View Post
    Thanks again, Dave
    Hello Dave, curious as to what you ended up doing here?
    Oct 2017
    south-central WY
    If you have a Trac-Loc or similar limited slip differential, both rear tires must be the same diameter, or the clutch material in the rear end will wear out very quickly. In this case if you get a flat rear tire, you may want to move a front tire to the rear and mount the spare on the front. If you're running different size tires front to rear, this isn't an option.
    Quote Originally Posted by Cokeologist View Post
    Hi Scott,
    I bought a 175/65 R14 Mohave tire from Discount tire. It sticks up a little above the OEM wheel well. but I used some little 1/2 inch pieces of wood under the OEM cardboard/plywood and we are good to go
    This one caught me the other day... Remember if you upgrade to 5 lug, you need a new 5 lug spare...
    On my 5 bolt conversion I bought a vision 17x4 1/2 wheel and use a Mickey Thompson S/R tire. I got caught out with a 50 mile/50 mph temp spare on a road trip and will never worry again about needing to go 100 miles on a spare at a reasonable hiway speed.
    Steve
    1983 Mustang GT
    Popular Hot Rodding Project Car '83/84
    1983 Capri 331 ci, TKO600
