Results 1 to 8 of 8
    Default 83-86 LTD Sedan Filler neck to trunk seal part number?
    Ran into yet another snag.|
    Anyone have a good part number look-up to find the number for the filler neck to trunk seal for the LTD/Marquis sedans? Fox Mustang one is a no-go.
    Thanks!
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Will it not fit or is it unavailable?
    I got mine from LMR and had to modify 1 of the holes
    Might work on the 79-82 cars, but for sure is not going to fit the 83-86 sedans.
    The drawing on the left is the tracing of the hole in the LTS. The part on the right is the "Fox" Mustang one.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Well my car is put away, or else i would check it.
    Do you have a pic of your old seal?
    Never had one with the car. The tracing is from the hole that's there.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
    Gotcha.
    I went through my pics
    I don't have a pic of the hole with no seal.
    All i have is a before and after.
    Before
    After
    Like i said i had to relocate one of the mounting holes. You can tell which one it's the lower left one.
    Hope this helps, sorry if it doesn't.
    The 79-82 cars are probably different. There is no way the Mustang seal is going to fit my car. It won't even fully cover the opening in the body.
    Also, I wouldn't be able to use any more than 1 of the existing holes.
    83 TC "Clone"
    85 Marquis LTS
    86 LTD Wagon
