Results 1 to 6 of 6
    Default 1984 GT350 VIN Check
    Hello, my uncle just purchased an '84 GT350, VIN - 1FABP28M7EF174066 - Would love to have that decoded so we can get it back to as stock as possible, thanks! @foxchassis
    -Randy
    '83 Mustang GL notchback - 351w - T5Z
    '84 Mustang GT350 20th Anniversary Hatch #2808 - 302 - T5
    ''92 Mustang LX Hatch - 2.3t - IRS (in progress)
    VIN will not tell you anything other than it is a 1984 5.0L hatchback. It will not positively identify it as a G.T.350. To do that with just a VIN you would need a Marti report.
    What will positively identify it as a G.T.350 is the door tag and or buck tag and or build sheet.
    Axle Tag Decoder
    Buck Tag Decoder
    Door Tag Decoder
    Owner Card Decoder
    Transmission Tag Decoder
    VIN Decoder
    Got it, thanks. I'll give him a call later and tell him how to find the buck tag and look for the build sheet.
    -Randy
    Buck and door tag decoded... Thanks for providing these resources!
    1FABP28M7EF174066
    MUSTANG = Mustang model line
    174066 = 74,066th 1984 Ford scheduled for production at Dearborn Assembly
    61B = Mustang 3-dr sedan (hatchback)
    M = H.O. 5.0L V8 engine
    MO = moonroof (sunroof)
    1281 = body & paint rotations #1281
    9LL = Oxford White exterior paint color
    DF
    ST
    AC = manual air conditioner
    04 = YES rear defrost, YES rear wing
    HB = heated backlite (rear defrost)
    S = speed control (cruise control)
    ANN = G.T.350 model/trim level
    PW = power side windows (no power door locks)
    MBW = manual Borg Warner transmission (5-speed T-5)
    01 = no hood scoop
    ELECTRIC
    -D = Canyon Red interior trim color
    NLR
    Date - 03/84 = March 1984 build
    GVWR - 4025 lb/1825 kg = gross vehicle weight rating
    Front GAWR - 2081 lb/943 kg = front gross axle weight rating
    Rear GAWR - 1997 lb/905 kg = rear gross axle weight rating
    F0061 = 0061 lbs front accessory reserve load
    R0160 = 0160 lbs rear accessory reserve load
    Exterior Paint Colors - 9L = Oxford White
    DSO - 24 = Jacksonville district sales office
    Body - 61B = Mustang 3-door sedan (hatchback)
    Int Trim - PD = cloth Articulated Sport seating (P), Canyon Red interior trim color (D)
    AC - GD = G.T.350 stripes (5.0L)
    R - 8 = AM/FM stereo radio with auto-reverse cassette tape player
    S - C = sunroof
    Ax - Z = 3.08:1 axle ratio, Traction-Lok (limited slip) differential
    Tr - 2 = manual Borg Warner transmission (T-5 5-speed overdrive)
    55 = front springs
    xx = rear springs
    -Randy
    If you would, please post the tags you have I collect and database them. Thanks.
    -Randy
