Results 1 to 9 of 9
Thread: Initial timing
    Default Initial timing
    Hello all,
    I have a new 302 with AFR 185 heads and a Ford F303 cam. Can some one tell me the best method is to find the the optimum initial and total timing. The engine doesn't like 14 degrees btc but, I'm not sure how to find out the optimum timing.
    Tom
    The absolute best way is to put it on an engine dyno, other than that it's seat of the pants and advancing until it has a negative effect.
    Not sure why it doesn't like 14 degrees initial timing. Could you tell us the ignition setup you're running? How are you checking the timing? Did you confirm TDC mark on the damper?
    Mar 2003
    Lowell, Oregon
    Start with the factory 10. No knocking advance to 12. This is a seat of the pants way referred to up there ^.
    Checking those other things is a great idea, just in case. Be sure all is mechanically proper.
    You are disconnecting the vacuum hose and plugging it right?
    Thank you both. The motor has very low miles but, is new to me. MSD ignition mechanical advance with a new damper and confirmed TDC.
    Tom
    Barboursville, WV
    Fwiw, I have a 302 that will barely run at 14. It wants more timing... both initial and total. It's had several different distributors and msd boxes (currently running a Pertronix box, which I really like). I've changed timing sets and cam. I've verified tdc and even had two very experienced mechanics look at it. Not sure what's going on with it but it runs great with a bunch of advance.
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    That's where I'm headed.
    Barboursville, WV
    For the record, I don't believe my timing is actually that far advanced. I just think I'm getting the wrong reading. It may have something to do with my timing light's compatibility with my ignition box. I feel like the timing is spot on. Basically, I kept advancing it a little at a time until it was a little slow turning over (engine warm). Then, I backed it off a hair. I've never experienced any knock or pinging.
    Nov 2004
    Chas. SC
    Old school timing was to advance till you heard a knock and then back off 2 degrees...
    Remember that different octane fuel will knock at different point.
    Albert Einstein
    1984 20th Anniversary GT350
    Almost "Stock"
    I'll try that,
    thanks
