The harness i have for the conversion has a pink wire and black and white wire with a 2 prong female plug on it for power. There is no corresponding unused plug end in the harness behind the driver side kick panel. The question is. Do i cut the female conector off and splice the wires into the harness? If so witch wires? Also i saw on a youtube vidio that you need to plug in a 20 amp fuse that of course assumed the wires were pluged into the harness. Any help is greatly appreciated.
