Results 1 to 5 of 5
    Default Vapor canister question
    Ok just got my 86 GT back after months of the guy working on it just dragging his feet. I had the egr deleted because I’m went with off-road xpipe. After driving around for a few days and smelling a lot of gas , I realize he removed my vapor canister when I didn’t tell him to do so. So looking under hood I see one vacuum line that was for the egr. I see two additional closer to inner fender going toward front of car . Would those be for the vapor canister? I know I need a hose run from under the intake too. LMR sells the whole kit. I need to get this hooked back up ASAP. Thanks. Any pics would be appreciated.
    Ok so after watching a video those other two lines went to the othe egr vacuum ports. So now i also understand how the canister is hooked up. But where does the purge valve get plugged into? Thanks
    Great question, i would like to know that myself
    Dah Dah Dah
    Da-da Dah Dah
    86Stripper....and 80sDave.....
    See http://vb.foureyedpride.com/showthre...eed-parts-info
    and bask in it. Two pages peeps!
    Perfect thanks .
