    Sep 2011
    Clarksville Indiana
    Default Front wheel not centerd
    I have 85 GT upr kmember,. Arms, caster camber plates,coil overs, fox ball joint with spacers, 94/95 spindles. After mounting everything up my front wheels are not centered in fender well which is causing tires to hit on the bottom part of fender. I adjusted the casters as far as possible which improved it some but not enough. Anyone have any ideas as to what would be causing this issue. I was talking to someone the other day and they ask if maybe I have sn95 aarms instead of foxbody. In think there a little longer would this cause the issue I'm having . Thanks.
    Sent from my Pixel 3 using Tapatalk
    Barboursville, WV
    I seem to recall some aftermarket a-arms will cause this. Which ones do you have?
    79 Pace Car - 331, t5
    79 Pace Car- 302, 4 spd
    82 Capri- working on 302, t5
    82gt - working on 408w, c4
    Sep 2011
    Clarksville Indiana
    UPR foxbody.
    I also went through the same thing. Old school D&D K member and tubular arms. Many aftermarket companies change the geometry to have an effect on handling due to more castor. I killed 2 birds with one stone. I had a bit of a fitment issue with my 3.5" downpipe, the hood wouldn't clear the intake due to the windsor motor and now the wheels are too far forward in the wheel wells. I tossed on a 1/2" K member spacer kit, and slid the K member back as far as it would possibly go and it helped with the wheel centering and the downpipe issue. I haven't tossed the hood back on to test that fitment yet. I am not 100% certain that I won't rub, so I picked up some adjustable control arms too just to be able to pull the wheels in a bit (I have new edge spindles, so my wheels stick out 8mm more than your setup with the early sn spindles)
    Sep 2011
    Clarksville Indiana
    Ok thanks I'll look into this
